Pokaż wyniki od 1 do 10 z 11
Wątek: Procedura adaptacji skrzyni ZF6HP19/21 po resecie adaptacji
    Oct 2017
    BMW 740i F01
    Post Procedura adaptacji skrzyni ZF6HP19/21 po resecie adaptacji
    Może komuś się przyda, dokładny opis jazd adaptacyjnych w naszych autach, po skasowaniu adaptacji:
    1. Step 1 Adaptation Re-Learn Procedure (D-Mode)
    1) From a standstill, accelerate the vehicle in D Mode with very light throttle (15-25% if monitoring pedal angle with MHD) to 4th gear
    2) Continue to accelerate with light throttle (20-40%) to 6th gear
    3) Let the vehicle coast to ~25mph, then slow the vehicle to a standstill with light brake
    application
    4) With the brakes applied and the vehicle at a standstill, wait for 10 seconds
    5) Repeat steps 1-4 for 9 cycles, then proceed to Step 2 below (M-Mode)
    2. Step 2 Adaptation Re-Learn Procedure (M-Mode)
    1) With the shifter in M Mode, accelerate the vehicle to ~30mph and select 3rd gear
    2) Continue driving for 2 miles
    3) Accelerate the vehicle to ~45mph and select 5th gear
    4) Using light throttle, accelerate to 50mph and then coast to ~40mph without applying the
    brakes, repeat for 4 cycles, then
    5) Accelerate to 55mph and select 6th gear
    6) With light throttle, accelerate to 65mph then coast to 50mph without applying the brakes,
    7) Select 3rd gear and repeat steps 1-6 for 5 cycles, then coast to a standstill and proceed to
    Step 3 below
    3. Step 3 (Shift Confirmation)
    1. With the vehicle at a standstill, shift from “N” to “D”, wait 5 seconds then shift back into “N”
    2. Repeat this for 4 cycles, then
    3. Shift from “N” to “R”, wait 5 seconds then shift back into “N”
    4. Repeat this for 4 cycles, then
    5. Check error memory to ensure there are no codes
    This concludes the basic procedure for re-learning the transmission adaptations. Please keep in mind that the transmission will continue to learn over the next few days to completely learn itself into the new parameters and shift quality will continue to improve. Drive the vehicle as normal.
    Podaj proszę źródło tego opisu.
    Oct 2017
    BMW 740i F01
    Propulsive Dynamics
    Tu jest dokładna procedura firmy ZF w poscie nr 5 napisanym przez kolegę @Cursor http://7er.pl/showthread.php/47520-A...ptacja+skrzyni
    Tak naprawdę to nic nie trzeba robić tylko jezdzić a ona się sama wszystkiego nauczy. Z każdym przejechanym kilometrem po skasowaniu adaptacji będzie chodziła coraz poprawniej.
    Ostatnio edytowane przez miro ; 16-05-2018 o 23:49
    Oct 2017
    BMW 740i F01
    Ok, u mnie po skasowaniu adaptacji od razu pracowała dobrze, nic nie szarpała. Aż sprawdziłem, czy się stara adaptacja skasowała, ale tak, wszędzie było 0. Od czego to zależy?
    Jak w 8HP skasować adaptacje?
    Przeleć ten temat
    https://translate.google.com/transla...79&prev=search
    ori wersja https://f30.bimmerpost.com/forums/sh....php?t=1182679
    Istą, podobnie jak w 6HP ;)
    Ciekawe - w sumie dużo osób pisze, że pomaga trik z wciśnieciem gazu :)
    Spróbuje :)
    Spróbuje :)
    Jak mogłeś jeszcze tego nie spróbować ???? Wstydź się :)
  1. [diagnoza] kasowanie adaptacji e65
    Przez dawide65 w dziale Diagnostyka / AUDIO / VIDEO / NAVI
    Ostatni post / autor: 21-08-2017, 08:53
  2. [silnik] Reset adaptacji ecu e65 3.0d
    Przez lysy106 w dziale Seria e65 / e66 / e67
    Odpowiedzi: 16
    Ostatni post / autor: 12-05-2017, 11:12
  3. [skrzynia] Kasowanie adaptacji skrzyni biegów programem z pakietu gdzie jest Inpa
    Przez cursor w dziale instrukcje / schematy
    Ostatni post / autor: 19-04-2016, 21:04
  4. E38 bledy sond i adaptacji
    Ostatni post / autor: 13-01-2016, 12:35
  5. [diagnoza] Procedura kasowania adaptacji w m62tu
    Przez tomaszeklolek w dziale Diagnostyka / AUDIO / VIDEO / NAVI
    Ostatni post / autor: 22-09-2013, 19:25
