Pokaż wyniki od 1 do 1 z 1
Wątek: BŁĘDY w INPA E38 HELP :(
    Vip Vip Awatar marcin8181
    Jan 2013
    Piastów
    Post BŁĘDY w INPA E38 HELP :(
    Mam problem od jakiegoś czasu . Wywala mi takie błędy
    Czy ktoś może mi pomóc w szukaniu usterki lub cos podpowie ???
    AUto na LPG
    error memory test V1.41 BMW TI-433 Teepe
    E R R O R M E M O R Y R E P O R T
    Date: 04/12/15 16:17:19
    ECU: IKE
    JobStatus: OKAY
    Variant: IKE
    RESULT: 2 errors in error memory !
    199 lever-type sensor 1
    Error frequency : 5
    Short circuit to batt+
    Sporadic error
    215 lever-type sensor 2
    Error frequency : 5
    Sporadic error
    Date: 04/12/15 16:17:36
    ECU: IHKR38
    JobStatus: OKAY
    Variant: IHKR38
    RESULT: 1 errors in error memory !
    19 Inner temperature sensor
    Error frequency : 24
    Date: 04/12/15 16:18:05
    ECU: ASC5
    JobStatus: OKAY
    Variant: ASC5
    25 stop light switch cabel
    Error frequency : 254
    Vehicle speed 2.75 km/h
    ASC passive
    ABS-control passive
    stop light switch on
    ASC-control passive
    Date: 04/12/15 16:19:06
    ECU: VIDEO_TV
    JobStatus: OKAY
    Variant: VIDEO_TV
    2 watchdog has been activated
    Error frequency : 6
    Date: 04/12/15 16:19:20
    ECU: DM338DS1
    JobStatus: OKAY
    Variant: DM338DS1
    RESULT: 6 errors in error memory !
    15 Ignition circuit surveillance
    Error frequency : 60
    Engine speed 960.00 rpm
    Battery Voltage 9.79 V
    Invalid working area (Plausibility fault)
    Fault stored after de-bouncing delay
    Error present
    Sporadic error
    ------------------------------------------------------------- Sondy były jakiś czas temu zmieniane (co prawda katy sa wyciete zrobił to ktoś przedemną i wstawiono emulator) podejrzewam ze to moze przez to te anomalia z sondami.. .ale rada kogoś mądrzejszego odemnie mile widziana :)
    201 Lambda integrator Bank 1
    Error frequency : 52
    Engine speed 1440.00 rpm
    Load signal 1.55 ms
    Short circuit to ground
    Exhaust gas relevant fault
    Error not present
    Sporadic error
    203 Lambda integrator Bank 2
    Error frequency : 57
    Engine speed 3520.00 rpm
    Load signal 3.10 ms
    Error not present
    Sporadic error
    12 Lambda probe signal Probe 2
    Error frequency : 45
    Coolant temperature 84.75 Grad Celsius
    Interruption
    Error not present
    Sporadic error
    ------------------------------------------------------------- Auto zaczeło mieć mniej mocy i zaczeło szarpać i trząść budą , po doczłapaniu się pod dom cos mu odbiło i zaskoczył i odzyskał utracone siły ...
    52 Ignition Cylinder 5
    Error frequency : 49
    Engine speed 120.00 rpm
    Battery Voltage 10.47 V
    Interruption
    Error not present
    Sporadic error
    Załączone pliki Załączone pliki
  1. [elektronika] INPA co to za błędy ??
    Przez cinek325 w dziale Seria e38
    Ostatni post / autor: 01-10-2013, 12:35
  2. [silnik] INPA błędy - proszę o pomoc E38 735i
    Przez dmisieekk w dziale Seria e38
    Ostatni post / autor: 31-07-2013, 09:03
  3. błędy E38 INPA
    Przez KAMILOS w dziale Diagnostyka / AUDIO / VIDEO / NAVI
    Ostatni post / autor: 20-07-2013, 18:08
  4. [diagnoza] Błędy - INPA - E38 740i
    Przez neonunit w dziale Diagnostyka / AUDIO / VIDEO / NAVI
    Ostatni post / autor: 24-02-2013, 21:34
  5. [elektronika] błędy w INPA
    Przez e4r5t w dziale Seria e38
    Ostatni post / autor: 22-03-2012, 21:19
