Zamieszczone przez shogun
...There are three acceleration sensors: one each for the front and rear axles (vertical motion), and one for longitudinal motion. All three sensors are made from the same material and are solid state, piezo ceramic elements. Vehicle movement on the sensors is converted into an electric signal. The control unit uses these inputs to detect road surface condition, vehicle loading and degree of motion. The loading of the vehicle influences vertical motion and is therefore detected by the sensors. The road speed input comes from the Electronic Body Module (EKM). The steering angle sensor contains a potentiometer with two wipers which signal the control unit how far and how fast the steering wheel is turned. Motion Sensor Steering Angle Sensor The signals received from the sensors are processed by the control unit, which sends signals to solenoids on the front and rear shock absorbers. The system response can be varied by the driver by selecting the Sport (S) or the Comfort (K) position on the console mounted program switch....
