WDS - sa info na temat dzialania calego systemu sterowania nawiewami i jest rozpisany ten czujnikCytat:
Zamieszczone przez coboss
INPA - jest wartosc, ktora po zaslonienu czujnika spada, takze czujnik napewno dziala i jest wykorzystywany do korekt.
Kod:Solar sensors
The solar sensor is installed in the indirect ventilation grille in the vicinity of the LED for the antitheft alarm system to allow for varying light and heat source conditions (solar radiation) and to influence temperature, air distribution and air volume control .
It consists of two photoresistors , one on left and one on right that sense the different intensity levels of the solar radiation . The temperature control is influenced by the parameters stored in the EEPROM for changing following functions:
* The blower curve is shifted
* The stratification air temperature is changed
* The ventilation flap angles are changed
The sensor signal is output in a voltage range from 0 - 5 V and updated every 10 seconds . The signal plausibility is checked by a limit monitoring facility so that the sensor influence may be disabled in the case of fault .
