1 zał±cznik(ów)
BŁĘDY w INPA E38 HELP :(
Witam,
Mam problem od jakiego¶ czasu . Wywala mi takie błędy
Czy kto¶ może mi pomóc w szukaniu usterki lub cos podpowie ???
AUto na LPG
error memory test V1.41 BMW TI-433 Teepe
E R R O R M E M O R Y R E P O R T
Date: 04/12/15 16:17:19
ECU: IKE
JobStatus: OKAY
Variant: IKE
RESULT: 2 errors in error memory !
199 lever-type sensor 1
Error frequency : 5
Short circuit to batt+
Sporadic error
215 lever-type sensor 2
Error frequency : 5
Sporadic error
Date: 04/12/15 16:17:36
ECU: IHKR38
JobStatus: OKAY
Variant: IHKR38
RESULT: 1 errors in error memory !
19 Inner temperature sensor
Error frequency : 24
Date: 04/12/15 16:18:05
ECU: ASC5
JobStatus: OKAY
Variant: ASC5
25 stop light switch cabel
Error frequency : 254
Vehicle speed 2.75 km/h
ASC passive
ABS-control passive
stop light switch on
ASC-control passive
Date: 04/12/15 16:19:06
ECU: VIDEO_TV
JobStatus: OKAY
Variant: VIDEO_TV
2 watchdog has been activated
Error frequency : 6
Date: 04/12/15 16:19:20
ECU: DM338DS1
JobStatus: OKAY
Variant: DM338DS1
RESULT: 6 errors in error memory !
15 Ignition circuit surveillance
Error frequency : 60
Engine speed 960.00 rpm
Battery Voltage 9.79 V
Invalid working area (Plausibility fault)
Fault stored after de-bouncing delay
Error present
Sporadic error
------------------------------------------------------------- Sondy były jaki¶ czas temu zmieniane (co prawda katy sa wyciete zrobił to kto¶ przedemn± i wstawiono emulator) podejrzewam ze to moze przez to te anomalia z sondami.. .ale rada kogo¶ m±drzejszego odemnie mile widziana :)
201 Lambda integrator Bank 1
Error frequency : 52
Engine speed 1440.00 rpm
Load signal 1.55 ms
Short circuit to ground
Exhaust gas relevant fault
Error not present
Sporadic error
203 Lambda integrator Bank 2
Error frequency : 57
Engine speed 3520.00 rpm
Load signal 3.10 ms
Error not present
Sporadic error
12 Lambda probe signal Probe 2
Error frequency : 45
Coolant temperature 84.75 Grad Celsius
Interruption
Error not present
Sporadic error
------------------------------------------------------------- Auto zaczeło mieć mniej mocy i zaczeło szarpać i trz±¶ć bud± , po doczłapaniu się pod dom cos mu odbiło i zaskoczył i odzyskał utracone siły ...
52 Ignition Cylinder 5
Error frequency : 49
Engine speed 120.00 rpm
Battery Voltage 10.47 V
Interruption
Error not present
Sporadic error
